주요 콘텐츠로 건너뛰기
Hasbro furby 2012 Light Sensor Replacement
필요한 것
  1. Hasbro furby 2012 Light Sensor Replacement, Outer Shell: 1 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement, Outer Shell: 1 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement, Outer Shell: 1 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
  2. Hasbro furby 2012 Light Sensor Replacement: 2 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 2 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #0 driver to unscrew the eight 10mm screws.
    • Remove the base ring after unscrewing all the screws.
    • Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
  3. Hasbro furby 2012 Light Sensor Replacement: 3 단계, 이미지 2개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Unhook the white ribbon from the tab on the base.
  4. Hasbro furby 2012 Light Sensor Replacement: 4 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 4 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement: 4 단계, 이미지 3개 중 3개
    • Roll the Furby's fur downward.
    • Disconnect the now exposed red wire.
  5. Hasbro furby 2012 Light Sensor Replacement: 5 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 5 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the two middle clips first.
    • Locate the two remaining clips on Furby's sides, they are opposite each other.
    • Orient the Furby upside down with the tail facing away from you.
  6. Hasbro furby 2012 Light Sensor Replacement: 6 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 6 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement: 6 단계, 이미지 3개 중 3개
    • Insert a metal prying tool directly into the clip opening.
    • Press upward into the clip. At the same time, use your other hand to pull away the plastic seam from the Furby's body.
    • Repeat the previous step to remove the remaining three clips.
  7. Hasbro furby 2012 Light Sensor Replacement: 7 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 7 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the two 10mm screws and remove them with the Phillips #0 head screwdriver.
    • Lift up on the fur covering until the face of the Furby is exposed.
  8. Hasbro furby 2012 Light Sensor Replacement: 8 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 8 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement: 8 단계, 이미지 3개 중 3개
    • Orient the Furby on its side to where the beak is facing left and locate the edge of the aluminum tape.
    • Lift tape gently and peel back until the tape is nearly removed.
    • Do not pull on the yellow wire located on the opposite end of the tape.
  9. Hasbro furby 2012 Light Sensor Replacement: 9 단계, 이미지 2개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 9 단계, 이미지 2개 중 2개
    • Locate the four 10mm screws. Two on either side of body, and two on top of back plate, around the tape.
    • Remove the 10mm screws with the Phillips#0 screwdriver.
  10. Hasbro furby 2012 Light Sensor Replacement: 10 단계, 이미지 1개 중 1개
    • Peel the tape gently, grabbing it from the bottom edge and folding the tape upward.
    • Peel the tape up until it is nearly detached from the black case.
  11. Hasbro furby 2012 Light Sensor Replacement: 11 단계, 이미지 2개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 11 단계, 이미지 2개 중 2개
    • Orient the Furby face down, with the base facing away from you.
    • Locate the clips below the ears.
    • Repeat the technique used in Step 6. Create leverage using a metal prying tool to press upward into the clip, while also pulling back on the clip itself.
  12. Hasbro furby 2012 Light Sensor Replacement: 12 단계, 이미지 2개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the loose, plastic back panel by pulling the panel away from Furby's body.
  13. Hasbro furby 2012 Light Sensor Replacement, Light Sensor: 13 단계, 이미지 3개 중 1개 Hasbro furby 2012 Light Sensor Replacement, Light Sensor: 13 단계, 이미지 3개 중 2개 Hasbro furby 2012 Light Sensor Replacement, Light Sensor: 13 단계, 이미지 3개 중 3개
    • Remove the 10mm Phillips #0 screw holding the circuit board in.
    • Gently lift out the circuit board.
  14. Hasbro furby 2012 Light Sensor Replacement: 14 단계, 이미지 2개 중 1개 Hasbro furby 2012 Light Sensor Replacement: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Orient the Furby with the tail pointing left and the face pointing right.
    • Use the pointed tweezers to spread open the socket, and the blunt tweezers to grip and tug out the connector.
    • Insert your replacement light sensor connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jordan Castillo
회원 가입일: 10/06/16
1,048 평판
안내서 5개를 작성함
Cal Poly, Team 15-5, Livingston Fall 2016 Cal Poly, Team 15-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 19
전체 시간: 1,741
