소개
The furby speaker is connected to a circuit board that is accessible once the outer shell is removed. Removing the connector tabs are the hardest part of this guide.
필요한 것
Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
Orient Furby to where the mouth is facing left. Locate the speaker on the side of the device.
Lift the speaker out.
이 단계에 사용된 도구:Tweezers$4.99
Use the blunt tweezers to pinch the latch on the speaker's casing. Detach the speaker from the both latches on both sides and remove the speaker's casing.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 3개
Where can i got speaker. Please help me. Thx so much.
What are the wattage ohm and diameter of the speaker?
