주요 콘텐츠로 건너뛰기
Haute42 S13 Button and Switch Replacement
필요한 것
  1. Haute42 S13 Button and Switch Replacement, Button Switch: 1 단계, 이미지 1개 중 1개
    • Unplug the controller from any device it is connected to and make sure it is powered off.
  2. Haute42 S13 Button and Switch Replacement: 2 단계, 이미지 3개 중 1개 Haute42 S13 Button and Switch Replacement: 2 단계, 이미지 3개 중 2개 Haute42 S13 Button and Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Use a keycap puller to remove the keycap from its socket.
    • Avoid using excessive force to prevent damaging the device.
  3. Haute42 S13 Button and Switch Replacement: 3 단계, 이미지 3개 중 1개 Haute42 S13 Button and Switch Replacement: 3 단계, 이미지 3개 중 2개 Haute42 S13 Button and Switch Replacement: 3 단계, 이미지 3개 중 3개
    • Use the keycap/switch puller to remove the switch from its socket.
    • Be careful not to damage the controller while removing the switch.
  4. Haute42 S13 Button and Switch Replacement: 4 단계, 이미지 2개 중 1개 Haute42 S13 Button and Switch Replacement: 4 단계, 이미지 2개 중 2개
    • Align the pins of the new switch with the holes in the socket and replace the switch.
    • You will feel the pins slide into place.
    • Do not press the switch in until you know you have aligned it correctly, doing so may damage the pins on the switch.
  5. Haute42 S13 Button and Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Use your finger to push the switch into place.
    • You should hear a click when it connects.
    • Try moving it to make sure it is firmly in place. It should not move at all when attached to the controller.
  6. Haute42 S13 Button and Switch Replacement: 6 단계, 이미지 3개 중 1개 Haute42 S13 Button and Switch Replacement: 6 단계, 이미지 3개 중 2개 Haute42 S13 Button and Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Align the cross on the keycap and the cross on the switch and gently press the keycap onto the switch.
    • Avoid applying excessive pressure to prevent damaging the new switch.
  7. Haute42 S13 Button and Switch Replacement: 7 단계, 이미지 1개 중 1개
    • Take a look at the OLED input display on the controller while pressing it to check if the button is fully functional.
    • On the screen, the button should highlight itself and the input history should be displayed at the bottom. If it all works, congratulations! You have successfully replaced this button.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Owen Santin
회원 가입일: 02/01/25
175 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 34
지난 30일: 125
전체 시간: 963
