주요 콘텐츠로 건너뛰기
Hayward SharkVac W3RC9740CUB Filter Panels Replacement
필요한 것
  1. Hayward SharkVac W3RC9740CUB Filter Panels Replacement, Hayward SharkVac W3RC9740CUB Filter Panels: 1 단계, 이미지 1/1
    • Unplug the robotic unit and set it on a flat surface.
  2. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 2 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 2 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 2 단계, 이미지 3/3
    • Gently turn the robotic unit onto its side with the unplugged power cord side facing up.
    • Hold on to the top of the robot to ensure it doesn't fall and break.
    • Keep your left hand on top of the unit for support while pushing the button in on the front.
    • While holding the button in, lift the cover up.
  3. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 3 단계, 이미지 1/1
    • Gently set the robotic unit back down on the flat surface.
  4. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 4 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 4 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 4 단계, 이미지 3/3
    • Lift the the filter bucket up to remove it from the unit, and set it on the ground.
  5. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 5 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 5 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 5 단계, 이미지 3/3
    • Using both hands, gently pull the filter door latches on the left out to the sides and lift the door upward.
  6. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 6 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 6 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 6 단계, 이미지 3/3
    • Using both hands, gently pull the filter door latches on the right out to the sides and lift the door upward.
  7. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 7 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 7 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 7 단계, 이미지 3/3
    • Gently wiggle the filter panel closest to you from side to side and pull it upward to remove it.
  8. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 8 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 8 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 8 단계, 이미지 3/3
    • Remove the second filter panel on the opposite side by gently wiggling it from side to side and pulling it upward.
  9. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 9 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 9 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 9 단계, 이미지 3/3
    • Insert the new filter panel furthest from you into the slot, making sure the black plastic is facing the center of the bucket.
  10. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 10 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 10 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 10 단계, 이미지 3/3
    • Insert the new filter panel into the slot closest to you, ensuring that the black plastic faces the center of the bucket.
  11. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 11 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 11 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 11 단계, 이미지 3/3
    • Bring the filter door latches down on both sides of the filter panels to lock them into place.
  12. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 12 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 12 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 12 단계, 이미지 3/3
    • Place the filter bucket back in the center of the robotic unit.
  13. Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 13 단계, 이미지 1/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 13 단계, 이미지 2/3 Hayward SharkVac W3RC9740CUB Filter Panels Replacement: 13 단계, 이미지 3/3
    • Close the top of the unit, ensuring that the button in the front locks into place.
결론
Now you have successfully changed the filter panels in your robotic vacuum pool cleaner. Happy swimming!
다른 한 분이 해당 안내서를 완성하였습니다.
LauraS
회원 가입일: 03/02/24
247 평판
안내서 1개 작성함
Austin Community College, Team 52-8, Watkins Spring 2024 Austin Community College, Team 52-8, Watkins Spring 2024 회원
AUSTINCC-WATKINS-S24S52G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 51
