주요 콘텐츠로 건너뛰기
Dodge Ram 1500 Headlight Bulb Replacement
필요한 것
  1. Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: 1 단계, 이미지 1/3 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: 1 단계, 이미지 2/3 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: 1 단계, 이미지 3/3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. Dodge Ram 1500 Headlight Bulb Replacement: 2 단계, 이미지 1/1
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. Dodge Ram 1500 Headlight Bulb Replacement: 3 단계, 이미지 1/3 Dodge Ram 1500 Headlight Bulb Replacement: 3 단계, 이미지 2/3 Dodge Ram 1500 Headlight Bulb Replacement: 3 단계, 이미지 3/3
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  4. Dodge Ram 1500 Headlight Bulb Replacement: 4 단계, 이미지 1/2 Dodge Ram 1500 Headlight Bulb Replacement: 4 단계, 이미지 2/2
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
    Is there any kind of plastic screw/bolt keeping the assembly in? I removed all the bolts listed and the assembly still would not come out. What am I missing?
    lpkzach92 - 답글
  5. Dodge Ram 1500 Headlight Bulb Replacement: 5 단계, 이미지 1/2 Dodge Ram 1500 Headlight Bulb Replacement: 5 단계, 이미지 2/2
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
  6. Dodge Ram 1500 Headlight Bulb Replacement, Headlight Bulb: 6 단계, 이미지 1/2 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Bulb: 6 단계, 이미지 2/2
    • Rotate the outer ring of the headlight bulb holder counterclockwise to remove it.
    • Carefully pull the headlight bulb holder out of its socket.
    • When installing a headlight bulb, do not touch the bulb with your bare skin. Wear gloves when installing a new headlight bulb. Halogen bulbs are sensitive to skin oils, and the bulb may burn out quickly if you touch the bulb during installation.
    • If you accidentally touch the bulb, clean it immediately using rubbing alcohol on a clean cloth.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Saggese
회원 가입일: 10/05/12
1,021 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G24
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
What is that rubber gasket called or a part # please, mine is all torn from previous owner
diggemsmacks2000 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 70
30일 전: 299
전체 시간: 25,053
