주요 콘텐츠로 건너뛰기
Headset Adjustment
필요한 것
  1. Headset Adjustment, Headset Adjustment: 1 단계, 이미지 1개 중 1개
    • To start the adjustment process first loosen the stem steerer clamp bolts.
  2. Headset Adjustment: 2 단계, 이미지 2개 중 1개 Headset Adjustment: 2 단계, 이미지 2개 중 2개
    • If you feel a knocking sensation when pulling the front brake and rocking the handlebars forward and back, then the headset needs to be tightened.
    • Turning the handlebars 90 degrees and repeating the process can help to ensure that any knocking sensations are not coming from play within the brake mechanism.
  3. Headset Adjustment: 3 단계, 이미지 2개 중 1개 Headset Adjustment: 3 단계, 이미지 2개 중 2개
    • Torque the bearing preload adjustment bolt on your stem cap just enough so that the knocking goes away.
    • Torque required is usually in the 2-3nm range.
    • If the steering feels rough or sluggish after tightening down the headset bearing preload bolt when turning your handlebars from side to side, you’ve over-tightened the headset.
    • Back it off an eighth or a quarter of a turn and check it again by turning the handlebars from side to side and pulling the front brake and rocking the handlebars front to back to feel for any knocking.
  4. Headset Adjustment: 4 단계, 이미지 1개 중 1개
    • If no amount of tightening eliminates the knocking, add a two or five millimeter spacer under your headset top cap to increase the available range of adjustment.
  5. Headset Adjustment: 5 단계, 이미지 1개 중 1개
    • Once you get a smooth steering feel without any knocking when performing the front brake test, your done with the adjustment and it is time to tighten the stem steerer clamping bolts.
    • Align the stem with the front wheel and torque the steerer clamp bolts to the manufacturer’s recommended torque spec.
결론
작성자
5다른 기여자 명과 함께
Daniel Slusser
회원 가입일: 07/21/14
349 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 193
