주요 콘텐츠로 건너뛰기
Health o Meter HDR743 Power Supply Replacement
필요한 것
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: 1 단계, 이미지 1/1
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: 2 단계, 이미지 1/1
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: 3 단계, 이미지 1/1
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: 4 단계, 이미지 1/2 Health o Meter HDR743  Power Supply Replacement: 4 단계, 이미지 2/2
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
결론
Dennis White Jr
회원 가입일: 04/02/18
217 평판
안내서 2개 작성하였습니다
University of Memphis, Team S1-G1, Kim Spring 2018 University of Memphis, Team S1-G1, Kim Spring 2018 회원
UM-KIM-S18S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 129
