주요 콘텐츠로 건너뛰기
Health o Meter HDR743 Wire Connection Replacement
필요한 것
  1. Health o Meter HDR743 Wire Connection Replacement, Wire Connection: 1 단계, 이미지 1/1
    • Use a voltmeter to check for power in the wires.
    • If the power is on, the voltmeter will give a reading. Verify if the red indicator light is visible.
  2. Health o Meter HDR743 Wire Connection Replacement: 2 단계, 이미지 1/1
    • Identify where the issue in the wire begins.
    • If the problem isn't near a connection, use wire strippers to cut away the troubled area, and splice a new wire in-between.
    • If the troubled area cannot be found, the entire wire will need to be replaced.
    • Use a soldering iron to remove the wire from its connection to the circuit board.
    • Use wire strippers to remove the wires from the other components.
  3. Health o Meter HDR743 Wire Connection Replacement: 3 단계, 이미지 1/1
    • Use a soldering iron to solder and splice a new wire to the component.
    • The other end of the wire should be spliced or soldered directly to the circuit board.
  4. Health o Meter HDR743 Wire Connection Replacement: 4 단계, 이미지 1/1
    • Test the new connection with the voltmeter.
    • If the issue persists, the repair has failed, or a different component is faulty.
결론
Dennis White Jr
회원 가입일: 04/02/18
217 평판
안내서 2개 작성하였습니다
University of Memphis, Team S1-G1, Kim Spring 2018 University of Memphis, Team S1-G1, Kim Spring 2018 회원
UM-KIM-S18S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 125
