필요한 것
Use a voltmeter to check for power in the wires.
If the power is on, the voltmeter will give a reading. Verify if the red indicator light is visible.
Identify where the issue in the wire begins.
If the problem isn't near a connection, use wire strippers to cut away the troubled area, and splice a new wire in-between.
If the troubled area cannot be found, the entire wire will need to be replaced.
Use a soldering iron to remove the wire from its connection to the circuit board.
Use wire strippers to remove the wires from the other components.
