주요 콘텐츠로 건너뛰기
Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair
필요한 것
  1. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair, Heated Bed: 1 단계, 이미지 3개 중 1개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair, Heated Bed: 1 단계, 이미지 3개 중 2개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair, Heated Bed: 1 단계, 이미지 3개 중 3개
    • Remove the four screws from the corners of the panel covering the controller board.
    • This may be found in various places of the printer depending on the model of the printer. Refer to the user manual or trace back wires from the heated bed.
    • The most common areas include: mounted on the side of the printer, underneath in the base of the printer, and inside an externally located control box.
  2. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 2 단계, 이미지 3개 중 1개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 2 단계, 이미지 3개 중 2개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 2 단계, 이미지 3개 중 3개
    • Locate the heated bed and temperature sensor connectors.
    • Here on the MKS Gen L V1.0 it is labeled H-BED and TB for Heated Bed and Thermistor Bed. Refer to a Pinout Diagram for your specific board.
    • Common boards include: Creality V1/V2, MKS Gen L V1.0/V1.4, MKS BASE V1.4, Einsy RAMBo, SKR v1.3/v1.4.
    • Remove the connection for the heated bed.
    • Remove the connector for the temperature sensor.
  3. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 3 단계, 이미지 3개 중 1개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 3 단계, 이미지 3개 중 2개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 3 단계, 이미지 3개 중 3개
    • Remove four thumb nuts from the corners of the heated bed.
    • Use a screwdriver if needed to hold screws in place while removing the thumb nuts.
    • Remove the heated bed from the Y-carriage.
  4. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 4 단계, 이미지 3개 중 1개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 4 단계, 이미지 3개 중 2개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 4 단계, 이미지 3개 중 3개
    • Desolder the damaged cable or connector.
    • For tips on soldering, check out the 연결부 납땜 및 납제거 방법 guide.
    • Take note of the polarity and which is for power and the thermistor. You may wish to take a picture for future reference. Red is for '+', Black is for '-'.
    • Do not use force to remove the cable or connector; doing this may rip the pads out.
    • Work in a well ventilated area when soldering; a fume extractor is recommended.
  5. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 5 단계, 이미지 2개 중 1개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Remove the old solder by using a solder pump or solder wick.
    • Re-tin the pads with fresh solder.
    • Use isopropyl alcohol to clean up any residue around the connections.
  6. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 6 단계, 이미지 3개 중 1개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 6 단계, 이미지 3개 중 2개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 6 단계, 이미지 3개 중 3개
    • Strip 1/4" from both ends of the wire and tin.
    • Check out the following guide for help with stripping wires: 전선 피복 벗기기.
    • Solder the wire onto the heated bed.
    • It is safe to bridge the connection if both pads are of the same polarity.
    • If your bed has a built-in LED, polarity will matter, otherwise it does not matter. Polarity does not matter on thermistor.
  7. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 7 단계, 이미지 2개 중 1개 Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 7 단계, 이미지 2개 중 2개
    • Apply Kapton Tape over the connection.
    • Solder an XT60 connector to the other end of the wire.
    • How to Use Heat Shrink Tubing
    • Terminate cables coming from the controller board with an XT60 connector as well.
    • If polarity matters, take note when soldering the XT60 connector.
  8. Heavily Modified or Homemade 3D Printer Heated Bed Connection Repair: 8 단계, 이미지 1개 중 1개
    • Reinstall and calibrate the heated bed.
결론
To reassemble your device, follow these instructions in reverse order. You may want to calibrate the Z-axis end stops and re-level the bed before printing.
작성자
2다른 기여자 명과 함께
Stephen Luu
회원 가입일: 09/17/20
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 1,046
