주요 콘텐츠로 건너뛰기
Heel Tip Replacement
필요한 것
  1. Heel Tip Replacement, Heel Tip: 1 단계, 이미지 1/1
    • Measure the size of your heel tips to know what size to purchase.
    • Most sizes are in the range of 8-13 mm. The variety packs are handy, especially if you have a few pairs to fix.
    • The size pictured in this fix is a 12mm heel tip on a size 9 heel.
  2. Heel Tip Replacement: 2 단계, 이미지 1/1
    • Wedge a dull picket knife or jimmy between the top of the heel tip to help loosen and separate the tip.
  3. Heel Tip Replacement: 3 단계, 이미지 1/2 Heel Tip Replacement: 3 단계, 이미지 2/2
    • Carefully remove the heel tip with the pliers by twisting and pulling it out. Most can be turned counter clockwise to remove. Be careful not to pull only the rubber off.
  4. Heel Tip Replacement: 4 단계, 이미지 1/2 Heel Tip Replacement: 4 단계, 이미지 2/2
    • Clean the newly exposed tip of any debris.
  5. Heel Tip Replacement: 5 단계, 이미지 1/1
    • Place the pin end of the new tip into the heels opening.
  6. Heel Tip Replacement: 6 단계, 이미지 1/2 Heel Tip Replacement: 6 단계, 이미지 2/2
    • Gently tap the new tip in with the hammer. Careful not to damage the shoes material.
  7. Heel Tip Replacement: 7 단계, 이미지 1/2 Heel Tip Replacement: 7 단계, 이미지 2/2
    • Adjust the tip with the pliers to align the heel tip.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Stephanie Shipman
회원 가입일: 01/22/17
479 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 150
30일 전: 675
전체 시간: 84,259
