주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Herringbone Stitch on a Split Seam
필요한 것
  1. Herringbone Stitch on a Split Seam, Intro to the herringbone stitch: 1 단계, 이미지 2개 중 1개 Herringbone Stitch on a Split Seam, Intro to the herringbone stitch: 1 단계, 이미지 2개 중 2개
    • Structure - The herringbone stitch consists of a series of alternating slanted stitches, creating a crosshatch pattern.
    • Repair Use - This stitch provides excellent stretch, making it ideal for knit and stretch fabrics. It's effective when fabric edges touch or slightly overlap, making it a strong choice for repairing damaged coverstitch seams.
  2. Herringbone Stitch on a Split Seam, Assess the damage: 2 단계, 이미지 3개 중 1개 Herringbone Stitch on a Split Seam, Assess the damage: 2 단계, 이미지 3개 중 2개 Herringbone Stitch on a Split Seam, Assess the damage: 2 단계, 이미지 3개 중 3개
    • Locate the damaged area and trim away any loose or hanging threads.
    • If necessary, pin the seam together so that it stays in place during stitching.
  3. Herringbone Stitch on a Split Seam, Plan the stitch: 3 단계, 이미지 2개 중 1개 Herringbone Stitch on a Split Seam, Plan the stitch: 3 단계, 이미지 2개 중 2개
    • The herringbone stitch follows two parallel lines, with the thread creating a crisscross pattern between them.
    • Before beginning, determine:
    • Stitch Width - The distance between the two parallel stitch lines. Mark both lines with chalk or heat-erasable pen.
    • Diagonal Stitch Length - The length of the diagonal stitch moving from one stitch line to the other that creates the crosshatch pattern.
    • Backstitch Length - The length of the small backstitch that secures each diagonal stitch.
    • These measurements will determine the structure and appearance of the herringbone stitch.
  4. Herringbone Stitch on a Split Seam, Start the stitch: 4 단계, 이미지 3개 중 1개 Herringbone Stitch on a Split Seam, Start the stitch: 4 단계, 이미지 3개 중 2개 Herringbone Stitch on a Split Seam, Start the stitch: 4 단계, 이미지 3개 중 3개
    • Thread the needle with a length of thread approximately 24 inches (~61 cm) and tie a knot at one end of the thread. For more details see Needles and Thread.
    • In the pictured repair, embroidery floss is used for visibility.
    • From the backside, insert the needle through to the front at a marked stitch line. Overlap any existing stitching by at least 1/2 inch (~13 mm).
    • In the pictured repair, remnant stitch lines from a missing coverstitch will be followed.
    • Pull the thread through until the knot lies flush against the back of the fabric.
  5. Herringbone Stitch on a Split Seam, Make a diagonal stitch: 5 단계, 이미지 3개 중 1개 Herringbone Stitch on a Split Seam, Make a diagonal stitch: 5 단계, 이미지 3개 중 2개 Herringbone Stitch on a Split Seam, Make a diagonal stitch: 5 단계, 이미지 3개 중 3개
    • On the front side, move the needle diagonally across the seam in the direction of the stitch path.
    • Insert the needle into the opposing stitch line at the Diagonal Stitch Length determined in Step 3.
    • Make a small stitch backwards along the marked stitch line with the Backstitch Length determined in Step 3.
    • If sewing through two layers, ensure both fabric layers are caught in the backstitch.
    • Pull the thread through.
  6. Herringbone Stitch on a Split Seam, Continue the stitch: 6 단계, 이미지 2개 중 1개 Herringbone Stitch on a Split Seam, Continue the stitch: 6 단계, 이미지 2개 중 2개
    • Move diagonally across the seam again.
    • Insert the needle, make a backstitch, and pull the thread through.
    • Keep the Stitch Width, Diagonal Stitch Length and the Backstitch Length consistent to create an even, durable stitch pattern.
  7. Herringbone Stitch on a Split Seam, Continue the stitch: 7 단계, 이미지 2개 중 1개 Herringbone Stitch on a Split Seam, Continue the stitch: 7 단계, 이미지 2개 중 2개
    • Repeat the diagonal and backstitch sequence, forming a crisscross pattern along the seam.
    • Continue stitching until the repair extends at least 1/2 inch (~13 mm) beyond the damaged area.
  8. Herringbone Stitch on a Split Seam, Tie off the thread: 8 단계, 이미지 3개 중 1개 Herringbone Stitch on a Split Seam, Tie off the thread: 8 단계, 이미지 3개 중 2개 Herringbone Stitch on a Split Seam, Tie off the thread: 8 단계, 이미지 3개 중 3개
    • To complete the stitch, move the needle to the backside and make a secure knot on the backside of the fabric using one of the techniques from Knot Thread to the Fabric (2 Ways).
  9. Herringbone Stitch on a Split Seam, Quality check: 9 단계, 이미지 2개 중 1개 Herringbone Stitch on a Split Seam, Quality check: 9 단계, 이미지 2개 중 2개
    • Ensure the stitches have effectively secured the seam.
    • For additional strength and coverage, repeat these steps to add another stitch line.
    • Placing the new stitch staggered from the original can create an appealing design.
    • Creating more compact stitches will also create a more durable stitch.
    • THREAD TENSION: Consistent thread tension is essential for a durable and flexible herringbone stitch. If the stitches are too tight, the fabric may pucker. If the stitches are too loose, the repair may lack stability.
    • Check the tension frequently while stitching, especially when repairing a slit or split seam, where fabric edges may shift.
    • Adjust as needed by gently pulling or loosening the thread to ensure the stitches lie flat without distorting the fabric.
    • Pause periodically to smooth the fabric and confirm the stitch tension is even along the repair.
결승점
작성자
2다른 기여자 명과 함께
Clara Redwood
회원 가입일: 11/12/24
2,565 평판
안내서 19개를 작성함
Patagonia Patagonia 회원
Community
9 회원들
안내서 143개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 27
지난 30일: 94
전체 시간: 817
