주요 콘텐츠로 건너뛰기
Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement
필요한 것
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: 1 단계, 이미지 1/2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: 1 단계, 이미지 2/2
    • Position the headphones so that you can see the opening for the cushion as you take out your blue iFixIt opening tool. In between the earpad cushion and the headset, place the iFixit opening tool.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 2 단계, 이미지 1/1
    • The connectors that the cushion snaps into place are used to attach the cushion to the headset. The connectors could be damaged by applying too much force, which would prevent the cushion from returning to its original position.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 3 단계, 이미지 1/1
    • After the earpad cushion has been disconnected from the connectors you can take your new earpad cushion and install it.
  4. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: 4 단계, 이미지 1/2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: 4 단계, 이미지 2/2
    • After removing the ear pad cushion, unscrew the four 1.6mm black screws with your Phillips-head screwdriver.
  5. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 5 단계, 이미지 1/2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 5 단계, 이미지 2/2
    • Use the Phillips-head screwdriver to remove the black casing screws.
    • Lift the casing to see the battery.
  6. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 6 단계, 이미지 1/1
    • The central spherical piece of metal is the battery. Use the ifixit opening tool and pry open the battery in your direction to remove the battery.
결론
Christopher Puperi
회원 가입일: 09/13/23
493 평판
안내서 5개 작성하였습니다
Austin Community College, Team 8-3, Watkins Fall 2023 Austin Community College, Team 8-3, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S8G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 118
