주요 콘텐츠로 건너뛰기
Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement
필요한 것
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement, Headband: 1 단계, 이미지 1/2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement, Headband: 1 단계, 이미지 2/2
    • With the opening tool, pry the plastic tabs that hold the headband to the headphones outward. Remove the plastic tab on both sides of the headband..
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: 2 단계, 이미지 1/2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: 2 단계, 이미지 2/2
    • The headband itself is held in by four 1.2mm screws where the tabs were. Remove the screws with 00 Phillips screwdriver.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: 3 단계, 이미지 1/1
    • Push outward and in your direction with the opening tool to separate the headband from the headphones. Replace by following the directions backwards.
결론
Christopher Puperi
회원 가입일: 09/13/23
493 평판
안내서 5개 작성하였습니다
Austin Community College, Team 8-3, Watkins Fall 2023 Austin Community College, Team 8-3, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S8G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 62
