소개
The hinges are necessary in order for the cushion and earpiece to remain in position while you are moving about or listening to music while wearing the headphones. If necessary, follow this guide to replace the hinges.
필요한 것
Bend the headset so that you can see the 1.2mm screws that need to be removed before removing the hinge. Next, take a hold of a Philips screwdriver size 00 and remove the screws.
거의 끝나갑니다!
결론
