주요 콘텐츠로 건너뛰기
Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement
필요한 것
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: 1 단계, 이미지 1/2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: 1 단계, 이미지 2/2
    • Bend the headset so that you can see the 1.2mm screws that need to be removed before removing the hinge. Next, take a hold of a Philips screwdriver size 00 and remove the screws.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement: 2 단계, 이미지 1/1
    • After removing the two screws, you can replace the hinge by removing it from the wire.
결론
Christopher Puperi
회원 가입일: 09/13/23
493 평판
안내서 5개 작성하였습니다
Austin Community College, Team 8-3, Watkins Fall 2023 Austin Community College, Team 8-3, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S8G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 93
