주요 콘텐츠로 건너뛰기
Heyday Round Bluetooth Speaker Disassembly
필요한 것
  1. Heyday Round Bluetooth Speaker Disassembly, Heyday Round Bluetooth Speaker: 1 단계, 이미지 2개 중 1개 Heyday Round Bluetooth Speaker Disassembly, Heyday Round Bluetooth Speaker: 1 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Disassembly: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
  3. Heyday Round Bluetooth Speaker Disassembly: 3 단계, 이미지 1개 중 1개
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  4. Heyday Round Bluetooth Speaker Disassembly: 4 단계, 이미지 1개 중 1개
    • Once the hardware is opened by the screwdriver, both sides of the motherboard will be exposed and ready for any needed repairs.
결론
To reassemble your device, follow these instructions in reverse order, from step 3 to step 1.
작성자
4다른 기여자 명과 함께
Hunter Brown
회원 가입일: 09/22/22
185 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 1,093
