주요 콘텐츠로 건너뛰기
Heyday Round Bluetooth Speaker Motherboard Replacement
필요한 것
  1. Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: 1 단계, 이미지 1/2 Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: 1 단계, 이미지 2/2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Motherboard Replacement: 2 단계, 이미지 1/3 Heyday Round Bluetooth Speaker Motherboard Replacement: 2 단계, 이미지 2/3 Heyday Round Bluetooth Speaker Motherboard Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  3. Heyday Round Bluetooth Speaker Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the two screws holding the motherboard in place.
  4. Heyday Round Bluetooth Speaker Motherboard Replacement: 4 단계, 이미지 1/2 Heyday Round Bluetooth Speaker Motherboard Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to disconnect the yellow wire from the motherboard by pinching the input and pulling away from the motherboard.
  5. Heyday Round Bluetooth Speaker Motherboard Replacement: 5 단계, 이미지 1/1
    • Carefully remove the motherboard by sliding it upwards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Sotelo
회원 가입일: 09/22/22
302 평판
안내서 2개 작성하였습니다
University of North Texas, Team 4-4, Saru Jimmy Fall 2022 University of North Texas, Team 4-4, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S4G4
4 회원들
안내서 3개 작성하였습니다
댓글 한 개
I have a Harman kardon onyx studio 5 speaker and it stop working, so I open it and discover the motherboard bent.I don't know where else to get it. Kindly help me out. My email is johnsonajen@gmail.com thanks🙏
Ajen Johnson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 319
