주요 콘텐츠로 건너뛰기
Heyday Round Bluetooth Speaker Motherboard Replacement
필요한 것
  1. Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker: 1 단계, 이미지 2개 중 1개 Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker: 1 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
  3. Heyday Round Bluetooth Speaker Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  4. Heyday Round Bluetooth Speaker Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Once the hardware is opened by the screwdriver, both sides of the motherboard will be exposed and ready for any needed repairs.
  5. Heyday Round Bluetooth Speaker Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the two screws holding the motherboard in place.
  6. Heyday Round Bluetooth Speaker Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Heyday Round Bluetooth Speaker Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to disconnect the yellow wire from the motherboard by pinching the input and pulling away from the motherboard.
  7. Heyday Round Bluetooth Speaker Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the motherboard by sliding it upwards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jonathan Sotelo
회원 가입일: 09/22/22
302 평판
안내서 2개를 작성함
1가이드 댓글
I have a Harman kardon onyx studio 5 speaker and it stop working, so I open it and discover the motherboard bent.I don't know where else to get it. Kindly help me out. My email is johnsonajen@gmail.com thanks🙏
Ajen Johnson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 39
전체 시간: 506
