주요 콘텐츠로 건너뛰기
Heyday Round Bluetooth Speaker Subwoofer Replacement
필요한 것
  1. Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker Disassembly: 1 단계, 이미지 1/2 Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker Disassembly: 1 단계, 이미지 2/2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Subwoofer Replacement: 2 단계, 이미지 1/3 Heyday Round Bluetooth Speaker Subwoofer Replacement: 2 단계, 이미지 2/3 Heyday Round Bluetooth Speaker Subwoofer Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  3. Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: 3 단계, 이미지 1/2 Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use curved tip tweezers to detach the connectors of two 2-prong Aux In/Out plugs extending from the subwoofer.
  4. Heyday Round Bluetooth Speaker Subwoofer Replacement: 4 단계, 이미지 1/2 Heyday Round Bluetooth Speaker Subwoofer Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the four screws at the edge of each subwoofer to release them.
    • Remove both subwoofers.
결론
Jonathan Sotelo
회원 가입일: 09/22/22
302 평판
안내서 2개 작성하였습니다
University of North Texas, Team 4-4, Saru Jimmy Fall 2022 University of North Texas, Team 4-4, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S4G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 7
전체 시간: 117
