주요 콘텐츠로 건너뛰기
Heyday Suitcase Turntable Motor Replacement
필요한 것
  1. Heyday Suitcase Turntable Motor Replacement, Platter: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Unlock the front latches and open the turntable suitcase cover.
    • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
    • Be careful, as the spindle shaft may fly off in an unexpected direction.
  2. Heyday Suitcase Turntable Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Use both hands to gently lift the platter up and off of the turntable.
  3. Heyday Suitcase Turntable Motor Replacement, Baseboard: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  4. Heyday Suitcase Turntable Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  5. Heyday Suitcase Turntable Motor Replacement: 5 단계, 이미지 2개 중 1개 Heyday Suitcase Turntable Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
  6. Heyday Suitcase Turntable Motor Replacement, Motor: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the screws connecting the motor and the baseboard.
    • The motor is located underneath the platter.
  7. Heyday Suitcase Turntable Motor Replacement: 7 단계, 이미지 1개 중 1개
    • Flip the baseboard over.
    • Unplug the cable connecting the motor to the baseboard.
    • Remove the motor.
결론
작성자
3다른 기여자 명과 함께
Caroline D'Amato
회원 가입일: 10/26/22
565 평판
안내서 6개를 작성함
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G1
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 493
