주요 콘텐츠로 건너뛰기
Heyday True Wireless Earbuds 8204 Battery Replacement
필요한 것
  1. Heyday True Wireless Earbuds 8204 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Pinch the tip of the earbud in one hand while gripping the base of the earbud in the other.
    • Gently pull the tip of the earbud apart from the base.
    • These pieces should come apart without the need for tools. Do not be afraid to use a little force.
  2. Heyday True Wireless Earbuds 8204 Battery Replacement: 2 단계, 이미지 1/2 Heyday True Wireless Earbuds 8204 Battery Replacement: 2 단계, 이미지 2/2
    • Put the base of the earbud aside as it will not be needed to access the speaker.
    • Gently pull the battery out from the earbud housing to reveal the wire that connects the two.
    • Do not pull the speaker forcefully. This may pull the wire out in a manner that damages the device.
  3. Heyday True Wireless Earbuds 8204 Battery Replacement: 3 단계, 이미지 1/1
    • Desolder the board connection to separate the red wire.
    • With the connection properly severed, pull the speaker unit out of the housing fully.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Peter Rocha
회원 가입일: 11/02/22
292 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-3, Petersen Fall 2022 UMass Dartmouth, Team 1-3, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S1G3
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 17
전체 시간: 464
