주요 콘텐츠로 건너뛰기
Heyday True Wireless Earbuds 8204 Case Motherboard Replacement
필요한 것
  1. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement, Case Motherboard: 1 단계, 이미지 1/1
    • Use a spudger or other prying tool to gently pry open the case from the metal hinge that connects the white part of the top and bottom of the case together.
    • Screwdrivers shouldn't be used as pry tools as they can damaged delicate internal components.
  2. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: 2 단계, 이미지 1/1
    • Using the spudger, going from the back of the case where the hinge used to be, pry the earbud charging housing up and remove it.
  3. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a Torx screwdriver to gently remove the six screws on the silver ring that holds in the motherboard and charging station.
  4. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: 4 단계, 이미지 1/1
    • Pull the silver bracket from the base of the case to reveal the motherboard.
    • Lift up and pull the motherboard out of the case.
결론
Ben Davignon
회원 가입일: 10/28/22
493 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-3, Petersen Fall 2022 UMass Dartmouth, Team 1-3, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S1G3
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 144
