주요 콘텐츠로 건너뛰기
Heyday True Wireless Earbuds 8204 Earbud Motherboard Replacement
필요한 것
  1. Heyday True Wireless Earbuds 8204 Earbud Motherboard Replacement, Earbud Motherboard: 1 단계, 이미지 1/1
    • Use a spudger or a pick and insert it into the small hole on the back side of the earbuds. Use it to pry the two halves of the earbud apart gently.
    • Don't use a screwdriver to pry the device as the delicate internal components are just inside the earbud.
  2. Heyday True Wireless Earbuds 8204 Earbud Motherboard Replacement: 2 단계, 이미지 1/1
    • Use a spudger to lift the motherboard out of the earbud gently. This should reveal the backside of the motherboard.
    • The motherboard is connected to speaker cables so don't pull the motherboard out yet.
    • The motherboard and other components can be damaged using tools such as a screwdriver or metal spuder to pry. Use ESD safe tools like a spudger or opening tool instead.
  3. Heyday True Wireless Earbuds 8204 Earbud Motherboard Replacement: 3 단계, 이미지 1/1
    • Now on the backside of the motherboard, detach the small red and black wires attached on the speaker to the motherboard using a spudger.
결론
Ben Davignon
회원 가입일: 10/28/22
493 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-3, Petersen Fall 2022 UMass Dartmouth, Team 1-3, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S1G3
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 183
