주요 콘텐츠로 건너뛰기
Heyday True Wireless Earbuds 8204 Hinge Bracket Replacement
필요한 것
  1. Heyday True Wireless Earbuds 8204 Hinge Bracket Replacement, Charging Housing: 1 단계, 이미지 1/2 Heyday True Wireless Earbuds 8204 Hinge Bracket Replacement, Charging Housing: 1 단계, 이미지 2/2
    • Use an ESD-safe pry tool to gently pry open the case from the metal hinge that connects the white part of the top and bottom of the case together.
    • This should come apart with just your hands and the tool. Any extra force may damage the product.
  2. Heyday True Wireless Earbuds 8204 Hinge Bracket Replacement: 2 단계, 이미지 1/1
    • Using the pry tool, go from the back of the case where the hinge used to be and pry up to pop out the charging housing.
  3. Heyday True Wireless Earbuds 8204 Hinge Bracket Replacement, Hinge Bracket: 3 단계, 이미지 1/2 Heyday True Wireless Earbuds 8204 Hinge Bracket Replacement, Hinge Bracket: 3 단계, 이미지 2/2
    • Use your H1.5 screw bit and gently remove the six screws on the silver retaining ring that holds in the motherboard.
    • After the screws are removed from the case, put the screws aside and remove the ring from the base.
결론
Peter Rocha
회원 가입일: 11/02/22
292 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-3, Petersen Fall 2022 UMass Dartmouth, Team 1-3, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S1G3
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 102
