주요 콘텐츠로 건너뛰기
Heyday Wireless Bluetooth Speaker 9979 Battery Replacement
필요한 것
  1. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement, Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 1 단계, 이미지 1개 중 1개
    • Remove the four bezels from the speaker's back cover.
    • Try to get under the bezel by using force, and pull it out little by little.
  2. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the four 1.6 mm screws. Rotate the driver counterclockwise to remove the screws.
  3. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 3 단계, 이미지 2개 중 1개 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the cover of the wireless speaker using the metal spudger. Don't use much force to remove it.
  4. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 4 단계, 이미지 2개 중 1개 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Once you have pulled the cover to the side, remove the two screws with a Philips #000 screwdriver. Turn counterclockwise.
  5. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 5 단계, 이미지 2개 중 1개 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • The battery might be glued down so use the black nylon spundger to take it out completely.
  6. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 6 단계, 이미지 3개 중 1개 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 6 단계, 이미지 3개 중 2개 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the nylon tipped tweezers, remove the motherboard carefully. It is recommended to grab the motherboard in the middle as there are no big buttons on it.
  7. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 7 단계, 이미지 3개 중 1개 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 7 단계, 이미지 3개 중 2개 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • You want to remove the white power cable connector from the motherboard. Start by using the fixit opening pick to pull it up. Once it is almost out, use you're fingers to just simply disconnect it.
결론
작성자
3다른 기여자 명과 함께
Thanh Duong
회원 가입일: 09/26/22
195 평판
안내서 1개를 작성함
CSU Los Angeles, Team 5-4, Adachi Fall 2022 CSU Los Angeles, Team 5-4, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G4
5 회원들
안내서 2개를 작성함
4가이드 댓글
The grammar could be improved by simplifying the steps (not using too many words or try separating into multiple bullet points) and avoiding the use of ambiguous pronouns (it).
Jadealyn Paulino - 답글
Will do, thanks!
Chris Yepez -
There are a lot of images and some are the same.
Cindy Munoz - 답글
The description of each tool needed was a very useful touch.
Cindy Munoz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 39
전체 시간: 698
