주요 콘텐츠로 건너뛰기
Hipstreet Titan 2 HD Camera Replacement
필요한 것
  1. Hipstreet Titan 2 HD Camera Replacement, Rear Case: 1 단계, 이미지 1/1
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Camera Replacement: 2 단계, 이미지 1/1
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Camera Replacement: 3 단계, 이미지 1/1
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Camera Replacement: 4 단계, 이미지 1/2 Hipstreet Titan 2 HD Camera Replacement: 4 단계, 이미지 2/2
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Camera Replacement: 5 단계, 이미지 1/2 Hipstreet Titan 2 HD Camera Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Camera Replacement: 6 단계, 이미지 1/1
    • Once the speaker is disconnected, the cover removal is complete.
  7. Hipstreet Titan 2 HD Camera Replacement, Camera: 7 단계, 이미지 1/2 Hipstreet Titan 2 HD Camera Replacement, Camera: 7 단계, 이미지 2/2
    • Use your plastic opening tool to lift the black ribbon connector lock.
    • Then, proceed to remove the camera.
  8. Hipstreet Titan 2 HD Camera Replacement: 8 단계, 이미지 1/1
    • Once the camera with the ribbon connector is removed, the process is complete.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeffrey
회원 가입일: 03/11/15
766 평판
안내서 5개 작성하였습니다
Colorado Springs, Team 5-6, Panko Spring 2015 Colorado Springs, Team 5-6, Panko Spring 2015 회원
UCCS-PANKO-S15S5G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 377
