주요 콘텐츠로 건너뛰기
Hisense Chromebook C11 Trackpad Replacement
필요한 것
  1. Hisense Chromebook C11 Trackpad Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Trackpad Replacement: 2 단계, 이미지 1/1
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Trackpad Replacement: 3 단계, 이미지 1/1
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Trackpad Replacement, Trackpad: 4 단계, 이미지 1/1
    • Remove the electrical tape.
  5. Hisense Chromebook C11 Trackpad Replacement: 5 단계, 이미지 1/3 Hisense Chromebook C11 Trackpad Replacement: 5 단계, 이미지 2/3 Hisense Chromebook C11 Trackpad Replacement: 5 단계, 이미지 3/3
    • Flip up the bracket holding the ribbon in place.
    • Gently but firmly pull the ribbon free.
  6. Hisense Chromebook C11 Trackpad Replacement: 6 단계, 이미지 1/1
    • Using the Phillips Head Screwdriver, remove the screws at the topmost part of the panel holding the trackpad in place.
  7. Hisense Chromebook C11 Trackpad Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the silver electrical tape.
  8. Hisense Chromebook C11 Trackpad Replacement: 8 단계, 이미지 1/1
    • Carefully remove the trackpad from the computer.
결론
Cole Welham
회원 가입일: 10/09/18
121 평판
안내서 1개 작성함
USF Tampa, Team S1-G3, Leahy Fall 2018 USF Tampa, Team S1-G3, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 293
