소개
The replacement of the back panel on the Hisense Chromebook C11 may seem complex at first but with a little guidance we’ll make it look new again. It's crucial to follow the steps carefully and proceed at your own risk. The trackpad also well known as the touch pad is what allows you to move the cursor on the screen. So, be mindful and follow the Step-by-step guide because they consist of delegate parts that need to be handle with care.
필요한 것
Remove the front two hub caps.
When finished, you should be able to remove the back cover.
