주요 콘텐츠로 건너뛰기
Hisense Sero 7 Pro Battery Replacement
필요한 것
  1. Hisense Sero 7 Pro Battery Replacement, Battery: 1 단계, 이미지 1/2 Hisense Sero 7 Pro Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Battery Replacement: 2 단계, 이미지 1/2 Hisense Sero 7 Pro Battery Replacement: 2 단계, 이미지 2/2
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Battery Replacement: 3 단계, 이미지 1/2 Hisense Sero 7 Pro Battery Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
결론
Baochau Nguyen
회원 가입일: 10/11/16
314 평판
안내서 3개 작성하였습니다
Texas Tech, Team 38-2, Bennett Fall 2016 Texas Tech, Team 38-2, Bennett Fall 2016 회원
TTU-BENNETT-F16S38G2
4 회원들
안내서 6개 작성하였습니다
댓글 2개
would be nice to actually have replacement battery avaible to buy new battery
howlingwolff10 - 답글
Where could one buy new battery?
Joshua Wood - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 2,652
