주요 콘텐츠로 건너뛰기
Hisense Sero 7 Pro Rear Camera Replacement
필요한 것
  1. Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/2 Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2/2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Rear Camera Replacement: 2 단계, 이미지 1/1
    • Using a metal or nylon spudger, begin to peel the tape from the motherboard that it is attached to the camera.
    • If needed, the same steps can be applied to front camera.
  3. Hisense Sero 7 Pro Rear Camera Replacement: 3 단계, 이미지 1/3 Hisense Sero 7 Pro Rear Camera Replacement: 3 단계, 이미지 2/3 Hisense Sero 7 Pro Rear Camera Replacement: 3 단계, 이미지 3/3
    • Pull the camera toward you to detach from the tablet.
    • Use caution when detaching camera from port.
결론
Baochau Nguyen
회원 가입일: 10/11/16
314 평판
안내서 3개 작성하였습니다
Texas Tech, Team 38-2, Bennett Fall 2016 Texas Tech, Team 38-2, Bennett Fall 2016 회원
TTU-BENNETT-F16S38G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 220
