주요 콘텐츠로 건너뛰기
Hisense Sero 7 Pro Speakers Replacement
필요한 것
  1. Hisense Sero 7 Pro Speakers Replacement, Battery: 1 단계, 이미지 1/2 Hisense Sero 7 Pro Speakers Replacement, Battery: 1 단계, 이미지 2/2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Speakers Replacement: 2 단계, 이미지 1/2 Hisense Sero 7 Pro Speakers Replacement: 2 단계, 이미지 2/2
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Speakers Replacement: 3 단계, 이미지 1/2 Hisense Sero 7 Pro Speakers Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
  4. Hisense Sero 7 Pro Speakers Replacement, Speakers: 4 단계, 이미지 1/3 Hisense Sero 7 Pro Speakers Replacement, Speakers: 4 단계, 이미지 2/3 Hisense Sero 7 Pro Speakers Replacement, Speakers: 4 단계, 이미지 3/3
    • Peel back the film holding the speaker wire in place
    • Detach both wire connectors
  5. Hisense Sero 7 Pro Speakers Replacement: 5 단계, 이미지 1/1
    • Using a plastic opening tool, carefully place under one corner of each speaker
    • Remove both speakers
결론
Logan Phillips
회원 가입일: 05/09/17
101 평판
안내서 1개 작성함
IUPUI, Team S4-G1, Harley Spring 2017 IUPUI, Team S4-G1, Harley Spring 2017 회원
IUPUI-HARLEY-S17S4G1
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 152
