주요 콘텐츠로 건너뛰기
Hisense Sero 8 Charging Port Replacement
필요한 것
  1. Hisense Sero 8 Charging Port Replacement, Charging Port: 1 단계, 이미지 1/3 Hisense Sero 8 Charging Port Replacement, Charging Port: 1 단계, 이미지 2/3 Hisense Sero 8 Charging Port Replacement, Charging Port: 1 단계, 이미지 3/3
    • Remove the back cover of the device using a combination of both plastic opening tools.
    • Use your plastic opening tool pry open a corner of the device, then continue down the side of the device with the tool to completely open the device.
  2. Hisense Sero 8 Charging Port Replacement: 2 단계, 이미지 1/1
    • Remove seven of the 4.43mm screws using the Philips #00 screwdriver.
    • It is not necessary to remove the bottom two 4.43mm screws that keep the speakers in place.
  3. Hisense Sero 8 Charging Port Replacement: 3 단계, 이미지 1/2 Hisense Sero 8 Charging Port Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Gently lift the motherboard up to extract the charging port out with the tweezers.
    • Be cautious not to disconnect any wires or ribbon cables.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Keanu
회원 가입일: 02/23/15
367 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 3,811
