주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Hisense Sero 8 Motherboard Replacement
필요한 것
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Hisense Sero 8 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Hisense Sero 8 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the back cover of the device using a combination of both plastic opening tools.
    • Use your plastic opening tool pry open a corner of the device, then continue down the side of the device with the tool to completely open the device.
  2. Hisense Sero 8 Motherboard Replacement: 2 단계, 이미지 1/2 Hisense Sero 8 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the black tape that is located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove seven of the 4.43mm screws using the Philips #00 screwdriver.
    • It is not necessary to remove the bottom two 4.43mm screws that keep the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unlock both latches to the ribbon cable connectors to remove the ribbon cables.
  5. Hisense Sero 8 Motherboard Replacement: 5 단계, 이미지 1/3 Hisense Sero 8 Motherboard Replacement: 5 단계, 이미지 2/3 Hisense Sero 8 Motherboard Replacement: 5 단계, 이미지 3/3
    • Unsolder the red, black, and yellow wires to properly remove the motherboard. Take a look at this guide to learn how to solder and unsolder connections.
    • Unsolder the black wire located on the top left of the device.
    • Once unsoldered, carefully lift the motherboard out of the device.
결론
Katharina
회원 가입일: 02/23/15
506 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,326
