주요 콘텐츠로 건너뛰기
Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
필요한 것
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: 1 단계, 이미지 1/1
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: 2 단계, 이미지 1/1
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: 3 단계, 이미지 1/1
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
결론
Mike
회원 가입일: 01/25/17
397 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-2, Banghart Winter 2017 Cal Poly, Team 9-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 422
