주요 콘텐츠로 건너뛰기
Hitachi HB-B102 Automatic Home Bakery II Motor Replacement
필요한 것
  1. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement, Outer Casing: 1 단계, 이미지 1/2 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Make sure to unplug the device before starting.
    • Remove the lid by opening it to a 45 degree angle and pulling out.
  2. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 2 단계, 이미지 1/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 2 단계, 이미지 2/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 2 단계, 이미지 3/3
    • Next, remove the two 1.3cm screws that hold on the control panel with a #2 Phillips head screwdriver. These screws, and the rest of the screws in this guide can all be removed using a #2 Phillips head screwdriver.
    • Then pull the control panel out of the device by using a metal spudger to pry it up. Flip it over and look at the back of the motherboard.
  3. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 3 단계, 이미지 1/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 3 단계, 이미지 2/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 3 단계, 이미지 3/3
    • You will then have to disconnect the six wires that connect the motherboard to the device. This can be done by firmly grasping a connector and pulling straight out from the unit. Once all of the wires have been disconnected, set aside the control unit.
  4. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 4 단계, 이미지 1/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 4 단계, 이미지 2/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 4 단계, 이미지 3/3
    • Remove the five 1cm screws that hold the the casing together. There will be two on each side, and one on the back.
  5. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 5 단계, 이미지 1/1
    • Unscrew the four 1.4 cm screws surrounding the slot for the bread pan.
  6. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 6 단계, 이미지 1/2 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 6 단계, 이미지 2/2
    • Now you can remove the top part of the assembly off by pulling straight up. Don't forget to gently pull your wires through.
  7. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 7 단계, 이미지 1/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 7 단계, 이미지 2/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 7 단계, 이미지 3/3
    • Flip the machine over so that the bottom is facing straight up. Then unscrew the four feet on the device with a #2 Phillips head screwdriver. The screws will stay in the rubber feet.
    • Next, remove the four 8mm screws on the four sides of the machine. You do not need to unscrew the screws on the front end corners.
    • Once the feet and screws are undone gently pull the metal plate off.
  8. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 8 단계, 이미지 1/1
    • Now that the bottom plate and top housing are off, you can gently pull the inner components out of the outer metal housing . This can be done by grabbing hold of the bread pan casing and slowly lifting the entire inner assembly straight up.
    • You now have access to the belt and motor.
  9. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement, Motor: 9 단계, 이미지 1/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement, Motor: 9 단계, 이미지 2/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement, Motor: 9 단계, 이미지 3/3
    • Locate the capacitor (aka the black box) to the left of the motor). Unscrew the 1cm screw holding the capacitor in place. The screw will stay with the capacitor.
    • Lift the capacitor and place to the side.
  10. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 10 단계, 이미지 1/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 10 단계, 이미지 2/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 10 단계, 이미지 3/3
    • Flip the bread maker on its side so you can access the bottom. The belt will need to be removed. For help on that please see: Hitachi HB-B102 Automatic Home Bakery II Belt Replacement
    • Unscrew the three 6mm screws holding the motor to the metal plate.
    • Gently pull the motor away from the metal plate.
  11. Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 11 단계, 이미지 1/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 11 단계, 이미지 2/3 Hitachi HB-B102 Automatic Home Bakery  II Motor Replacement: 11 단계, 이미지 3/3
    • Now that you have the motor out, locate the black cable coming out of the motor and linking it to two blue cables.
    • You'll need to cut this wire with scissors or wire cutters.
    • Next, you'll need to wire in your new motor. To do this follow this handy guide: Wire Stripping and Crimping 101
결론
Ally Swian
회원 가입일: 01/25/17
125 평판
안내서 1개 작성함
Cal Poly, Team 9-2, Banghart Winter 2017 Cal Poly, Team 9-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G2
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
The motor is freely turned, though the motor pulley never moves. Could the 8 micro farad motor capacitor bu bad…how do I test it?
Fred Seitz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 22
전체 시간: 971
