주요 콘텐츠로 건너뛰기
HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement
필요한 것
  1. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: 1 단계, 이미지 2개 중 1개 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: 1 단계, 이미지 2개 중 2개
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 2 단계, 이미지 2개 중 1개 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 3 단계, 이미지 2개 중 1개 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the remaining four 7 mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 4 단계, 이미지 3개 중 1개 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 4 단계, 이미지 3개 중 2개 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the two cables with the red and white ends by pushing down the center tab at the end and pulling them out of their sockets.
  5. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the power supply board.
결론
작성자
2다른 기여자 명과 함께
Johny
회원 가입일: 09/08/23
557 평판
안내서 4개를 작성함
0 Guide Comments
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 102
