주요 콘텐츠로 건너뛰기
Hockey Glove Palm Repair
필요한 것
  1. Hockey Glove Palm Repair, Hockey Glove Palm Repair: 1 단계, 이미지 1/1
    • Using measuring tape, measure the dimensions of the hole to approximate how much material is needed.
  2. Hockey Glove Palm Repair: 2 단계, 이미지 1/2 Hockey Glove Palm Repair: 2 단계, 이미지 2/2
    • Using the dimensions gathered from the previous step, cut the fabric to size leaving some excess material.
    • You can use fabric from other gloves that are still intact to repair the glove in need.
  3. Hockey Glove Palm Repair: 3 단계, 이미지 1/1
    • Draw an approximate shape of the hole on the fabric as a guide for stitching using a marking tool that will show up on fabric.
  4. Hockey Glove Palm Repair: 4 단계, 이미지 1/2 Hockey Glove Palm Repair: 4 단계, 이미지 2/2
    • Thread a needle with enough thread for the size of the hole you are repairing.
    • A sewing machine can be used instead of hand sewing if you would prefer.
  5. Hockey Glove Palm Repair: 5 단계, 이미지 1/2 Hockey Glove Palm Repair: 5 단계, 이미지 2/2
    • Apply the adhesive to the perimeter of the hole.
  6. Hockey Glove Palm Repair: 6 단계, 이미지 1/1
    • Position the material on the glove to completely cover the hole leaving a bit of overlap.
    • Allow the adhesive time to dry so that the material is firmly stuck to the glove.
  7. Hockey Glove Palm Repair: 7 단계, 이미지 1/2 Hockey Glove Palm Repair: 7 단계, 이미지 2/2
    • Reinforce replacement material to the palm through hand stitching.
    • To hand stitch, push the needle through the front of the fabric and pull the thread through. Do the same from the inside of the glove. Continue to weave in and out creating stitches that are as close together as possible.
  8. Hockey Glove Palm Repair: 8 단계, 이미지 1/1
    • Trim excess the material from around the area of replacement
결론
Dora D'Accardo
회원 가입일: 04/19/23
157 평판
안내서 1개 작성함
UC Davis, Team 1-6, Morris Spring 2023 UC Davis, Team 1-6, Morris Spring 2023 회원
UCD-MORRIS-S23S1G6
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 20
30일 전: 100
전체 시간: 1,959
