주요 콘텐츠로 건너뛰기
Holley 4 Barrel Carburetor Gasket Replacement
필요한 것
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: 1 단계, 이미지 1/3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: 1 단계, 이미지 2/3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: 1 단계, 이미지 3/3
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: 2 단계, 이미지 1/1
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: 3 단계, 이미지 1/1
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: 4 단계, 이미지 1/1
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: 5 단계, 이미지 1/1
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: 6 단계, 이미지 1/2 Holley 4 Barrel Carburetor Gasket Replacement: 6 단계, 이미지 2/2
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: 7 단계, 이미지 1/1
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: 8 단계, 이미지 1/1
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: 9 단계, 이미지 1/2 Holley 4 Barrel Carburetor Gasket Replacement: 9 단계, 이미지 2/2
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Chad Giesmann
회원 가입일: 06/01/16
186 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 32
전체 시간: 4,462
