주요 콘텐츠로 건너뛰기
Hollowtech Bottom Bracket Replacement
필요한 것
  1. Hollowtech Bottom Bracket Replacement, Bottom Bracket: 1 단계, 이미지 1개 중 1개
    • Secure the bicycle using a bicycle repair stand or wall.
  2. Hollowtech Bottom Bracket Replacement: 2 단계, 이미지 2개 중 1개 Hollowtech Bottom Bracket Replacement: 2 단계, 이미지 2개 중 2개
    • Use pliers to remove the spring clip from the chain's master link clip.
    • Remove the master link plate, plate and pin assembly, and finally the chain.
  3. Hollowtech Bottom Bracket Replacement: 3 단계, 이미지 3개 중 1개 Hollowtech Bottom Bracket Replacement: 3 단계, 이미지 3개 중 2개 Hollowtech Bottom Bracket Replacement: 3 단계, 이미지 3개 중 3개
    • Use a 10mm Allen key socket and ratchet to loosen the left crank arm by twisting counter clockwise.
    • Remove the left crank arm.
    • Remove the spacer(s) and washer.
  4. Hollowtech Bottom Bracket Replacement: 4 단계, 이미지 3개 중 1개 Hollowtech Bottom Bracket Replacement: 4 단계, 이미지 3개 중 2개 Hollowtech Bottom Bracket Replacement: 4 단계, 이미지 3개 중 3개
    • Either push or pull the crank arm fully out exposing the left bottom bracket.
  5. Hollowtech Bottom Bracket Replacement: 5 단계, 이미지 2개 중 1개 Hollowtech Bottom Bracket Replacement: 5 단계, 이미지 2개 중 2개
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the left bottom bracket by twisting counter clockwise.
    • Remove the bottom bracket.
  6. Hollowtech Bottom Bracket Replacement: 6 단계, 이미지 2개 중 1개 Hollowtech Bottom Bracket Replacement: 6 단계, 이미지 2개 중 2개
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the right bottom bracket by twisting counter clockwise.
  7. Hollowtech Bottom Bracket Replacement: 7 단계, 이미지 3개 중 1개 Hollowtech Bottom Bracket Replacement: 7 단계, 이미지 3개 중 2개 Hollowtech Bottom Bracket Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully pull out the bottom bracket shell.
결론
Congratulations, you have completed the guide. To reassemble the crankset, follow these instructions in reverse order. Make sure to grease the threads, bottom bracket shell, and crankset accordingly. In addition, torque down the crank arm (38-41Nm) and bottom bracket (40-50Nm) to the manufacturer's recommended specification.
작성자
1다른 기여자 명과 함께
Agustin Sernas
회원 가입일: 10/23/23
145 평판
안내서 1개를 작성함
CSU Los Angeles, Team 13-3, Ribeiro Fall 2023 CSU Los Angeles, Team 13-3, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S13G3
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 534
