주요 콘텐츠로 건너뛰기
Holmes Blizzard Fan Oscillation Button Replacement
필요한 것
  1. Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: 1 단계, 이미지 3개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: 1 단계, 이미지 3개 중 2개 Holmes Blizzard Fan Oscillation Button Replacement, Front Cage Removal: 1 단계, 이미지 3개 중 3개
    • Using a Phillips #2 Screwdriver, remove the 3 screws located on the back of the fan cage.
    • Next, loosen the screw located on the bottom of the fan.
    • The bottom screw does not need to be removed, but only loosened about 3 or 4 turns.
    • The front of the fan's cage is now able to be removed by prying the front away from the back.
  2. Holmes Blizzard Fan Oscillation Button Replacement: 2 단계, 이미지 3개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement: 2 단계, 이미지 3개 중 2개 Holmes Blizzard Fan Oscillation Button Replacement: 2 단계, 이미지 3개 중 3개
    • Using a 7 mm socket and wrench, remove the 2 nuts that are behind the fan blades.
    • There is a washer located behind each nut. Be sure not to lose these.
  3. Holmes Blizzard Fan Oscillation Button Replacement, Remove the Oscillation Button Screw: 3 단계, 이미지 2개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement, Remove the Oscillation Button Screw: 3 단계, 이미지 2개 중 2개
    • On the top of the fan, there is a screw fastening the oscillation button to the gear train within the housing. Remove this screw with the Phillips #0 Screwdriver.
  4. Holmes Blizzard Fan Oscillation Button Replacement, Housing Assembly Removal: 4 단계, 이미지 2개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement, Housing Assembly Removal: 4 단계, 이미지 2개 중 2개
    • The on/off and fan speed nob can be removed by simply pulling it away from the main housing.
  5. Holmes Blizzard Fan Oscillation Button Replacement: 5 단계, 이미지 3개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement: 5 단계, 이미지 3개 중 2개 Holmes Blizzard Fan Oscillation Button Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the 2 screws holding the clear plastic plate in place with a Phillips #2 Screwdriver.
    • The plate is now free and can be taken out by hand.
  6. Holmes Blizzard Fan Oscillation Button Replacement: 6 단계, 이미지 2개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement: 6 단계, 이미지 2개 중 2개
    • The motor switch is also free and can be removed by hand to reveal a screw holding the housing assembly in place.
    • Be sure not to damage the wires on the switch during removal. While you do not need to be overly gentle during this step, excessive force could cause the wires to be pulled out.
  7. Holmes Blizzard Fan Oscillation Button Replacement: 7 단계, 이미지 2개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the screw that holds the housing assembly in place by using a Phillips #2 Screwdriver.
  8. Holmes Blizzard Fan Oscillation Button Replacement: 8 단계, 이미지 3개 중 1개 Holmes Blizzard Fan Oscillation Button Replacement: 8 단계, 이미지 3개 중 2개 Holmes Blizzard Fan Oscillation Button Replacement: 8 단계, 이미지 3개 중 3개
    • The housing assembly can now be pulled off and pushed to the side to reveal the fan motor and gear train.
    • The oscillation button the was unscrewed earlier will fall out of the housing assembly.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mike Bolton
회원 가입일: 07/17/16
570 평판
안내서 2개를 작성함
4가이드 댓글
I wanted to let you know how pleasantly surprised I was to find your post when looking for instructions on the oscillation feature of my fan that is just like this one. Thank you for posting.
nancysmyowner - 답글
Thank you for this info. This made it so easy for me to take my fan apart and clean it.
Pamela Dacus - 답글
I used this guide to fix a Holmes Air HAOF-7, which is virtually identical. It was seizing and clicking while oscillating. Oiling the gear assembly fixed it right up. Thanks for posting!
Soft Serve - 답글
Thank you for this information, really helped me out a lot
Zane C. Waldon Sr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 44
전체 시간: 21,226
