주요 콘텐츠로 건너뛰기
Holmes HEH8031 Control Buttons Replacement
필요한 것
  1. Holmes HEH8031 Control Buttons Replacement, Housing: 1 단계, 이미지 1/1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: 2 단계, 이미지 1/1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: 3 단계, 이미지 1/2 Holmes HEH8031 Control Buttons Replacement: 3 단계, 이미지 2/2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: 4 단계, 이미지 1/1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: 5 단계, 이미지 1/3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 5 단계, 이미지 2/3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 5 단계, 이미지 3/3
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: 6 단계, 이미지 1/3 Holmes HEH8031 Control Buttons Replacement: 6 단계, 이미지 2/3 Holmes HEH8031 Control Buttons Replacement: 6 단계, 이미지 3/3
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Shaffer
회원 가입일: 10/12/16
255 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 464
