소개
Use this repair if you want to replace your fan blade assembly. Be sure to turn off the power and unplug the heater before beginning to change the fan assembly. The screws in this heater are recessed, so using a magnetic screwdriver will be helpful. Note: When reassembling the unit, you must replace the 2 machine screws that connect the rotor assembly to the housing before replacing the coarse-threaded screws. Aligning the machine screws may take some finesse.
필요한 것
Identify that you have the Holmes HEH8031 heater. The model number is on the bottom of the unit.
