주요 콘텐츠로 건너뛰기
Holmes HEH8031 Power Cord Replacement
필요한 것
  1. Holmes HEH8031 Power Cord Replacement, Housing: 1 단계, 이미지 1/1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Power Cord Replacement: 2 단계, 이미지 1/1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Power Cord Replacement: 3 단계, 이미지 1/2 Holmes HEH8031 Power Cord Replacement: 3 단계, 이미지 2/2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Power Cord Replacement, Power Cord: 4 단계, 이미지 1/3 Holmes HEH8031 Power Cord Replacement, Power Cord: 4 단계, 이미지 2/3 Holmes HEH8031 Power Cord Replacement, Power Cord: 4 단계, 이미지 3/3
    • Decrimp the wire nuts from both wire connections.
    • Remove wire nuts to expose wire strands.
    • Separate all connected wires.
  5. Holmes HEH8031 Power Cord Replacement: 5 단계, 이미지 1/3 Holmes HEH8031 Power Cord Replacement: 5 단계, 이미지 2/3 Holmes HEH8031 Power Cord Replacement: 5 단계, 이미지 3/3
    • Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
    • Separate the two halves of the cord clamp and remove from cord.
  6. Holmes HEH8031 Power Cord Replacement: 6 단계, 이미지 1/2 Holmes HEH8031 Power Cord Replacement: 6 단계, 이미지 2/2
    • Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
    • Strip at least 3/4 inch of insulation from the cord to expose bare wire.
    • Twist wire ends to form a tight braid.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Deanna Jack
회원 가입일: 10/12/16
333 평판
안내서 4개 작성하였습니다
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G1
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
Are there substitute power cord for Holmes HEH8031 power cord replacement?
Terri Allen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 1,920
