주요 콘텐츠로 건너뛰기
Holmes HEH8031 Safety Weight Replacement
필요한 것
  1. Holmes HEH8031 Safety Weight Replacement, Housing: 1 단계, 이미지 1/1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: 2 단계, 이미지 1/1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: 3 단계, 이미지 1/2 Holmes HEH8031 Safety Weight Replacement: 3 단계, 이미지 2/2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: 4 단계, 이미지 1/1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: 5 단계, 이미지 1/2 Holmes HEH8031 Safety Weight Replacement, Safety Weight: 5 단계, 이미지 2/2
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: 6 단계, 이미지 1/1
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
결론
Deanna Jack
회원 가입일: 10/12/16
333 평판
안내서 4개 작성하였습니다
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 540
