주요 콘텐츠로 건너뛰기
Holmes HEH8031 Thermostat Replacement
필요한 것
  1. Holmes HEH8031 Thermostat Replacement, Housing: 1 단계, 이미지 1/1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Thermostat Replacement: 2 단계, 이미지 1/1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Thermostat Replacement: 3 단계, 이미지 1/2 Holmes HEH8031 Thermostat Replacement: 3 단계, 이미지 2/2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Thermostat Replacement, Circuit Board Removal: 4 단계, 이미지 1/1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Thermostat Replacement, Fan: 5 단계, 이미지 1/1
    • Remove two Phillips #2 12mm screws from housing
  6. Holmes HEH8031 Thermostat Replacement: 6 단계, 이미지 1/1
    • Remove zip tie from wire with pliers
  7. Holmes HEH8031 Thermostat Replacement: 7 단계, 이미지 1/1
    • Separate fan assembly from heating coil
  8. Holmes HEH8031 Thermostat Replacement, Thermostat: 8 단계, 이미지 1/1
    • Remove 1 Phillips #2 screw
  9. Holmes HEH8031 Thermostat Replacement: 9 단계, 이미지 1/1
    • Remove thermostat from rear housing
  10. Holmes HEH8031 Thermostat Replacement: 10 단계, 이미지 1/1
    • remove solder from thermostat wire on circuit board
    • Soldering iron will be hot
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Richard S Woodruff
회원 가입일: 10/12/16
142 평판
안내서 1개 작성함
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,278
