주요 콘텐츠로 건너뛰기
Holystone HS 440 Controller Phone Stand Replacement
필요한 것
  1. Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: 1 단계, 이미지 1/3 Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: 1 단계, 이미지 2/3 Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: 1 단계, 이미지 3/3
    • Start by removing the battery lid on the back of the controller.
    • After removing the lid, take your Phillips #0 screwdriver and remove the two 2mm Phillips #0 screws located right below where the batteries go.
    • Make sure to remove all the AAA batteries before removing the back panel.
  2. Holystone HS 440 Controller Phone Stand Replacement: 2 단계, 이미지 1/3 Holystone HS 440 Controller Phone Stand Replacement: 2 단계, 이미지 2/3 Holystone HS 440 Controller Phone Stand Replacement: 2 단계, 이미지 3/3
    • Start prying the controller using the opening tool by sliding the tool through the breaks and applying some force to get it open. (it might require a bit of force)
    • After opening the controller, remove the four screws holding the phone stand and take the phone stand out.
결론
Joaquin Botello
회원 가입일: 02/08/24
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 48
