소개
A broken tile on an incomplete tile roof will be repaired through this guide. Roofing tiles are not only a sore thumb to look at but can also cause detrimental effects resulting in roof leaks and water damage. This guide will be a general overview on the correct process for repairing a tile roof.
필요한 것
Be cautious when climbing the ladder to the roof. Ensure your ladder is secure before climbing.
Ensure the damage has not reached the underlayment.
Secure the tile to the cement by pressing down on the tile using the handle of the hammer.
Use the handle of the hammer to maneuver into correct position.
As seen in the bottom of the picture, using too much cement can leak out from both sides of the tile. Be sure to keep it as hidden underneath the tile as possible.
To reassemble your device, follow these instructions in reverse order. Number one thing of importance is your safety, my goal is for this guide to give you a general idea of the steps it takes to construct/repair/replace a tile roof.
다른 한 분이 해당 안내서를 완성하였습니다.
