주요 콘텐츠로 건너뛰기
HomePod 2023 woofer Replacement
필요한 것
    • flip your speaker onto its back.
    • using your scissors, carefully cut through the fabric just enough so you can remove it from the speaker's body.
    • using your spludger, pry out the 8 plastic plugs that are hiding the screws.
    • using your screwdriver, remove the 8 screws that are holding the speaker's body together.
    • using your spludger, carefully pry into the base.
    • be careful as to not damage the ribbon cable that is still attached to the motherboard.
    • using your screwdriver, remove the 6 screws that are holding the speaker in place.
    • using the spludger, carefully pry under the speaker to get it out.
    • be very careful when prying as there are wires that are connected to the motherboard.
    • when replacing the new woofer, apply the new seal.
    • carefully using 2 fingers, remove both of the connectors that connect to the speaker from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
776831
회원 가입일: 06/10/21
1,034 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 741
