주요 콘텐츠로 건너뛰기
추천 문서
해당 분해도는 수리 안내서가 아닙니다. HomePod Mini 수리는 자사의 서비스 설명서를 사용하세요.
  1. HomePod Mini IC Identification, HomePod Mini IC Identification: 1 단계, 이미지 1개 중 1개
    • Side 1 IC Identification, Pt. 1:
    • Apple APL1W82 64-Bit Dual-Core Applications Processor w/ GPU with likely 1 Gb LPDDR3 SDRAM Memory
    • This is the same processor found in the Apple Watch Series 5, just not protected by a boatload of epoxy.
    • Apple 338S00553-A0 Power Management
    • Nordic Semiconductor nRF52833 Bluetooth 5.2 SoC w/ NFC and Zigbee
    • Skyworks SKY66404-11 2.4 GHz Zigbee/Thread/Bluetooth Front-End Module
    • USI 339M00117 WiFi/Bluetooth Module
    • USI UWB Transceiver
  2. HomePod Mini IC Identification: 2 단계, 이미지 1개 중 1개
    • Side 1 IC Identification, Pt. 2:
    • Analog Devices SSM3582A 31.76 W Filterless Stereo Class D Audio Amplifier
    • Texas Instruments CD3217B12 USB Type C Controller
    • Winbond W25Q80DVUXIE 8 Mb Serial NOR Flash Memory
    • Texas Instruments TPS62130B 3 A Step Down Converter
    • Texas Instruments INA199C3DCK Bi-Directional Current Sense Amplifier
    • Dialog Semiconductor SLG46140 Programmable Mixed Signal Array
    • 3 Likely Goertek MEMS Microphones are found around the perimeter of the PCB.
  3. HomePod Mini IC Identification: 3 단계, 이미지 1개 중 1개
    • Side 2 IC Identification:
    • Texas Instruments LP5030RJVR 30-Ch. Constant Current RGB LED Driver
    • Texas Instruments TPS55340RTE 5 A Boost Regulator
    • Austria Microsystems (AMS) Ambient Light Sensor
  4. HomePod Mini IC Identification: 4 단계, 이미지 3개 중 1개 HomePod Mini IC Identification: 4 단계, 이미지 3개 중 2개 HomePod Mini IC Identification: 4 단계, 이미지 3개 중 3개
    • Sensor Flex IC Identifications:
    • Texas Instruments HDC2010YPA Humidity/Temperature Sensor
    • Another likely Goertek MEMS Microphone
작성자
1다른 기여자 명과 함께
CChin
회원 가입일: 06/10/20
7,144 평판
안내서 7개를 작성함
3가이드 댓글
nRF52833 is used for Thread networking protocol. Refer to HomePod mini tech spec: https://www.apple.com/homepod-mini/specs...
Henry Churchill - 답글
I wonder when are they gonna allow homekit to access the temperature and humidity sensors of the homepod mini?
Jeremy - 답글
Hello, does anyone have any idea about the specs of the 2R2 inductor near the Texas Instruments TPS62130B 3 A Step Down Converter? Bought a dead HomePod Mini online to try and fix. I noticed that this component was missing on the board. Thank you!
Douglas Gee - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 49
지난 30일: 162
전체 시간: 11,613
